Configures an IGMP SSM mapping.
| group_ip | Specifies the multicast IP address for the group mapping. |
| prefix | Specifies a prefix length for the multicast group IP address. The range is 4 to 32. |
| mask | Specifies the network mask for the group multicast IP address. |
| source_ip | The IP address for a multicast group source. |
| src_domain_name | The source domain name for the multicast group source. |
| vr-name | Specifies a virtual router name. If the VR name is omitted, the switch uses the VR specified by the current CLI VR context. |
N/A.
IGMP SSM mapping operates only with IPv4.
The following example configures an IGMP-SSM mapping for the range of multicast IP addresses at 232.1.1.0/24 originating from IP host 172.16.8.1:
configure igmp ssm-map add 232.1.1.0/24 172.16.8.1
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
